1 - 2 of 2 Posts
SOLD SOLD SOLD
Had on my 09 just bought a 2020 Don't Need Anymore $100 + Shipping
Rowe Electronics PDM60 Power Distribution Module
The PDM60 provides 6 individual circuits, with a total load handling capability of 60 Amps. The unit is designed to connect directly to a primary (12V) power source (vehicle battery), and efficiently power, protect and monitor the supply of power to your electrical/electronic devices.
You are also able to create your own custom configuration, and load it into the PDM60 using a PC/laptop via the programming dashboard and custom programming cable. You’re able to configure individual circuit amperage limits, individual circuit triggering methods, circuit delay activation and delay off settings.
The PDM60 has been built with components selected for superior power management capability, and extended service life. It’s designed with one goal in mind: to provide years and years of superior, hassle free performance. The PDM60 unit is fully encapsulated to protect against rain, dust, humidity, etc. Whether it’s Motocross, or cross-country via interstate, these units are built to last under the harshest of conditions.
Features:
Makes adding or removing aftermarket electrical devices or electronics to your vehicle a breeze
Offers six power circuits to handle your favorite gadgets and accessories
Simple to install, simple to use
Connects directly to your vehicle's battery
Super bright LED indicators on the PDM60 keep you informed of the status of each circuit
Eliminates the need to check and replace fuses or install relays to power high amperage applications
Plain and simple, with the PDM60 module your bike will be better equipped
https://www.revzilla.com/motorcycle/rowe-electronics-pdm60-power-distribution-module?gclsrc=aw.ds&&gclid=Cj0KCQiA2ITuBRDkARIsAMK9Q7PpsbzTZ6oZ103mWWhiMfMfijnD7Uv4bO56Wzupzeyewfgpg2fs0BkaAvENEALw_wcB
1 - 2 of 2 Posts
