1 - 9 of 9 Posts
Hello, I recently bought a brand new 2015 GS... She already has 1000 miles
As here in my country there is no bmw service dealer, does anyone knows what do I have to perform on the 600 miles service?
I replaced the enginel oil-filter and transmision oil
Does the gearbox oil need to be replaced?
Service intervals and actions
A diagnostics device worth considering The Home of GS-911 ? HEX Code
Running-in Check / 600 miles (1.000 km) service:
Setting service-due date and service countdown distance
Performing vehicle test with BMW Motorrad diagnostic system
Oil change, engine, with filter
Oil change, rear wheel drive
Checking front and rear brake fluid level
Checking coolant level
Checking tire pressures and tread depth
Checking lights and signalling equipment
Function test, engine start suppression
Final inspection and check of roadworthiness
Confirming BMW Service in on-board documentation
Checking spoke tension (Adv.)
6.000 miles (10.000 km) service (30.000 km / 50.000 km):
Oil change, rear wheel drive (every 2 years)
Visual inspection of the hydraulic clutch system
Visual inspection of the brake pipes, brake hoses and connections
Checking front and rear brake pads for wear
Checking front and rear brake discs for wear
Changing brake fluid, front and rear brakes
Checking ease of movement of side stand
Checking ease of movement of centre stand
Checking battery charge state
12.000 miles (20.000km) service (40.000 km / 60.000 km):
Checking valve clearance
Replacing spark plugs
Replace air filter cartridge
If you do the work yourself keep records and receipts to show the work was done in case there is a warranty issue.
ShireReeve‘s link is excellent, as it goes directly to A&S Cycles (dealer) and offers up the “official” BMW maintenance sheets for all the bikes in PDF format.
This link from 2015 still works, but the schedules seem a bit dated. No mention of the final drive oil change which comes up on my service DVD as a 24k service item. I would include this item whenever changing the gear box oil (Pre-LC models).
Agreed. I noticed several glaring omissions like that, which are critical. Perhaps we can correlate with a schedule for an older bike and/or alternate manual.
1 - 9 of 9 Posts
