1 - 3 of 3 Posts
2018 R1200GSA
Tanklock ED bag, capacity 5 litre.
Materials: • 600D PU polyester coated polyurethane EVA, high resistance UV materials (ISO 4892-2) • Materials manufactured within REACH recommendations
Features: • Side reflective inserts • Rain cover • Handle for easy transportation • Internal glasses holder • Shoulder strap for easy transportation • Zipper pulls compatible with a safety lock • IP65 waterproof, removable mobile phone holder • Cable outlet for the GIVI Power Hub
The TanklockED system enables a tanklock bag to be secured to the specific flange mounted to the fuel cap, using a security lock thus ensuring increased security. The tanklock bag can be attached and detached from the fuel tank without using the key. The key is only used to secure the tanklock bag when the motorcycle is left unattended. The lock type used in the ED System can be matched to the security locks used in top and side cases, the trolley base and also the tool box by using one of the following lock sets; SL102 / SL103 or SL105.
Includes 2 keys also installed a SAE outlet which is perfect to run a short Powerlet to SAE cable for full charging capabilities inside the bag. The bag is in like new condition. This does not include the tank ring so you will need to look at the GIVI site to determine your needs. I paid $17.00 for the ring when I bought this bag.
The price is $120.00 shipped anywhere within the CONUS.
2018 R1200GSA
Sure thing - here is a side view and top view from my GSA. I can go from lock to lock with NO interference at all and as you can see in the photo, I have Rox pullback risers on my handlebars.
1 - 3 of 3 Posts
