1 - 13 of 13 Posts
2016 R1200GS with all the fixins including the Akro exhaust, purchased new in Sept 2016 (it's our two year anniversary!).
In the two years since buying the bike I have never noticed smoke from the exhaust before the two events below.
First occurrence: After a week long vacation during which the bike was sitting at home idle and covered. When I started the machine there was a decent amount of (grey-ish I think) smoke from the exhaust which slowly decreased until it eventually stopped, over a period of maybe 60 seconds or so. The next few days there was no smoke when starting the machine.
Second occurrence: This morning heading out for my commute to work. The bike had been idle for 3.5 days, and again the smoke on startup. Again the smoke started off somewhat heavy and then lessened over ~60 seconds. Rather ashamed I let the bike sit idle for more than 3 days but that is beside the point.
Should I be concerned?
I'll check the oil level tonight, pay closer attention to the colour of the smoke if I see it again. Maybe I'll let the bike sit a few days to see if I can re-create the issue and record it.
Mark
Based on related posts (I should have searched the forum first) I suspect it is / was water allowed to sit in the exhaust can. Odd that it has never happened before but maybe this is the first time I've had 1. water in the exhaust and 2. the bike sitting idle for a few days. I did give it a wash before leaving on that 1 week vacation.
Still, odd it's never happened before. My bike is always on its side stand unless I specifically need the centre stand for something.
I’ve had a 2014 R1200 GS since new, it’s now got about 45,000 km on it. Since about 20,000 km I started noticing smoke on start-up when it had been sitting on the side stand for more than a couple days, I’d say exactly as you’ve described. For this reason, I now only ever leave it parked on the centre stand at home (only use it every 2 weeks atm unfortunately). If I do this, it does not smoke on start-up. Out of about 20 non-BMW bikes I’ve had, this is the only bike that uses a noticeable amount of oil. About 200 mils per 10,000 km, not a lot but not what I’m used to. I’m not worried about it, most BM ppl say its normal - and I still love the bike!
By the way, if you drop it on its side...once you pick it back up and start it, it’ll smoke like crazy for a few minutes, I’ve had that a couple of times, but still no scratches on it ?
BMW says 1 liter per 1K miles is considered normal. On the 8K mile trip to Ak. and back a few months ago, my 2012 camhead used 1/2 liter in 4K miles. If you overfill them, they'll throw the excess through the air box.
1 liter = 33 fluid ounces? I know that from the capacity of a bottle of rum. A quart of oil every thousand miles sounds excessive. By that measure I would have consumed 3 gallons of oil in 12,000 miles?
2 cups in 4k sounds reasonable but I wouldn't want to see more than that...
Discussion Starter #9
My buddy was told the same thing (by a Milwaukee 8 certified H-D tech) regarding his 2017 H-D Road Guide Ultra when it had some issues during our recent trip to Newfoundland. I have a real hard time wrapping my head around the idea of a bunch of engineers sitting around designing motors with "specs" like this. My old 2006 Yammie FZ-6 lost zero ounces of oil per 1,000 miles. My old 2007 Toyota Corolla loses zero ounces of oil per 1,000 miles. And if either of them lost this much oil, I would consider them broken and would take them in for service.
1l per 1,000 miles means your putting in half a litre every day when you are out touring, and that is considered "ok". Makes no sense at all. Losing that much oil means there is something wrong. It's bonkers!
Not being an automotive engineer, makes no sense to me to push excess oil out the air breather either, which my buddy was also told his brand new RGU would do. For one, it gums up the air filter*. For two, why not drip the excess into the cylinders and just burn it off?
*which, on the RGU at least, eventually creates vacuum pressure that continues to extract oil from the motor until the oil soaked filter is replaced, eventually bleeding your motor dry. Again, according to one Milwaukee 8 certified tech.
It's not the engineers that set these tolerances for oil burn, it's the warranty claims department and they set the allowable oil consumption so high so that they don't have to repair engines.
I had a new GM product that used a bit over 2 quarts between oil changes (4-5k miles) and the dealer told me that was normal and within spec (1qt per 1k miles), it didn't make me happy though and I reported my displeasure to the service manager and than the general manager they ended up replacing the engine and the new one doesn't use any oil between changes.
Moral of the story is; just because the manufacturer says it's within spec doesn't always mean that you have to settle for that.
Not that the bikes use that much, only that bmw says that's what they consider normal. I've heard the GS's may use some until they get past 12-15K and nearly none after 20k on the bikes.
Like I mentioned, I used a liter in 4K miles to Ak. So I wasn't adding oil every 1K. On the GS, overfill the oil too much, it pushes the excess through the breather. To avoid that, don't overfill the oil, pretty simple right? :wink2:
Discussion Starter #12
Understood ... I'm guessing it is a warranty / legal thing.
I'm still bothered by the white smoke thing though. I know everyone says it is normal, but it is in fact the opposite of normal, given my bike was nearly 2 years old with ~27,000kms on the odo (and pretty much always on the side stand) before the first occurrence of "big puff of white smoke on startup".
White Smoke usually indicates water is present in the combustible mix..try watching your coolant level more often. Though not related to your issue I had a water pump replaced due to a seal failure(oil and water emulsification present).
1 - 13 of 13 Posts
