Special tool needed to remove sparkplug coil?
8627 Views 14 Replies 10 Participants Last post by  PerazziMx14
This is going to be my first attempt to do a 12K miles service on my 2017 GSA (previous services done by dealer). I watched a YouTube tutorial video, the man used a special tool to remove the sparkplug coil. It was done in a few seconds (hard to see: one hand on the tool and one hand on camera and he cut the shot short). He did not elaborate on the tool. 1) Anyone know that tool? Part number or links to buy the tool please. 2) Else, will I be able to remove the coil using the "normal" tools that anyone would have (pliers, screwdrivers, etc.)? Thank you.
1 - 15 of 15 Posts
There you go.
Reactions: 1
A good ole shoe string will work as well. Make sure you work the string up to the head of the coil and with steady even pressure gently pull the coil free to f the spark plug.
I do use the coil puller when working in the garage as it’s right in the tool cabinet. I do mot carry a motorcycle puller with meso I have practiced the string method in case I need it in the field.
Automotive lighting Hood Motor vehicle Automotive tire Automotive design
See less See more
Reactions: 2
Since you’re in the US - here’s the one I use
Reactions: 1
Thank you, all. With your help, I was able to find them on amazon.com.
Huh.. I just use the flat end of a screwdriver to gently pry it out. Never thought about some special tool.
Reactions: 1
2
I got the aluminum tool, it works well but, because I'm somehow obsessive about compact stuff, I cut the 'mushroom' head, drilled and I use a M6 bolt and a 1/4" fender washer. The bolt is a common size on our bike, so It's a spare.
30654
30655
See less See more
Reactions: 2
I would not know about the special tool until I saw a man who used it in his YouTube video.
When I checked my valves at 12000 miles, I just grabbed the stick coils by hand and twisted them gently back and forth while pulling and they both came out easily. Applied a tiny amount of grease before re-installation to make it easy for next time. Check out this guy:
And there is the Promach Dual Tool. Made in Montana.
Or Dual Tool Plus:
Reactions: 1
I love it! I thought I was the only one who used paracord to do this (I am too cheap to buy one of those single job tools). 👍🏼👍🏼
I bought these pliers a few years ago to help remove the quick release fuel line on another bike. They work surprisingly well for removing the GS plug caps.
30679
See less See more
Reactions: 1
This one is quiet smart, much easier to carry in our tool bags or tool boxes....I wish I had this idea
Obrigado !
Pliers and coil sticks are not a great match. Yes they do work but if you get a little ham-fisted you crack the potting.
Reactions: 1
1 - 15 of 15 Posts
