1 - 2 of 2 Posts
GSA Trev
When I turn the key on to start my 08 GSA, it takes 5-10 seconds before the lights come on the instrument cluster. Sometimes I need to turn the ignition off and back on before I get the lights to come on. It has no problem starting once the lights come on. I am curious if there is a fix for the delay.
Thanks in advance for any suggestions.
Administrator
Hey neighbor. :D
Assuming this just started recently? I'm not an electrical expert but if the battery checks out ok I'd be guessing either the immobiliser, the ring antenna or instrument cluster could be intermittent or going out, but I'd be guessing. Any warnings on dash?
I have a GS-911 if you want to plug in and see if there are any codes are present.
1 - 2 of 2 Posts
