1 - 4 of 4 Posts
I am looking for a 90 degree tire valve to fit into my 2009 1200GSA with stock rims. There is a variety of stems sold but I need to know which one will work as far as diameter size.
Any input will help.
Thanks.
Those brass screw on type weigh enough to cause problems. Not a good choice. You need ones that have the correct fitment size and are permanently mounted like traditional straight valve stems; preferably made of aluminum.
I believe the hole size on your rim is 11 mm, but you should veify that. Check one of the online parts fiches to confirm (http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx). Once you are sure of the size you can then search online for 90 degree aluminum valve stems in the correct size.
Reactions: mikec
jack walshe, 2005 r1200gs
Not much help but…
15 MM technically per 2012 GS fiche… spoke wheel non-TPMS 36317653064
11 MM right angled "might" work, but different brands may/not fit rim contours
8 MM right angled will not work (I tried!)
1 - 4 of 4 Posts
