Hi Bill, how Is the new cam chain tensioner holding up? Can you provide the part number for it? It should be on the paperwork you received from the dealer.I tried it all.....My 2019 RT started rattling at around 7000 miles. First thought it was pinging. I tried every brand of top tier premium fuel, different additives and octane boosters. Noise was still there. Tried cooler plugs...Bypassed the exhaust servo.....Noise still there. So I ruled out pre ign. a while back.
Dealer found a few valves slightly out of spec and cam timing off....Noise still there.
I've previously owned 3 other BMW boxers, and knew this just wasnt the "normal" chatter. Recently pushed my dealer again to contact BMW and see if there were any remedies. He checked and was told there is a new "upgraded" LH cam chain tentioner (he had to order the part from Germany). I had it installed this past Saturday. SO FAR it seems to have done the trick. Leaving tomorrow on a 4-day 2-up trip in the mountains. This will be the true test because my bike would rattle under load. Any type of incline, especially 2-up under 4300 rpm and at higher revs when getting on it.
I'll keep you guys posted. Dont want to give any false hopes until I really try it out.
thanks
