1 - 20 of 27 Posts
· Registered
Hi,
Do anyone know the difference between these two brand of crashbars? SW Motech is cheaper and can be purchased of eBay, Touratech is much more expensive and in the website there is a video explaining how good it is, no vibrations etc.
Has anyone bought the SW Motech crashbars?
· Registered
SW Motech uses thin mild steel tubing as opposed to the tougher tubing of the Touratech bars. Watch the Touratech video and pay attention to the the way the bars are mounted on a separate plate as opposed to directly to the engine. It is designed to flex and give potentially preventing engine damage in a crash.
· Registered
I have the SW Motech, they are fine. They are mild steel so will give a little in a crash and do not need an "engineered weak point" like the stainless steel Touratech bars.
Personally I find most of Touratech's stuff way too expensive for what it is, but maybe thats because I'm an engineer ;)
· Registered
To throw another idea out there I had very good results with Hepco & Becker bars. They were put to the test many times with dirt crashes, twice skidding down the road as a result of a low side, and surviving a wayward deer. The bars were bent up a bit and scratched. I mostly straightened them out but still needed to at least loosen them to remove the valve covers.
Anyway, they did their job well enough that I just ordered the wethead version of the H&B bars for my new GS -- the one BMW just started building and may not even show up in my garage for another month or two.
· Registered
SW-MOTECH uses 2.2mm thick (not thin) mild steel tubing. The purpose of this thickness and this material in the design of the SW-MOTECH bars is to help absorb the crash and not transfer it to the frame.
· Registered
Thin in comparison to the Touratech bars which are not designed to bend. I understand the different engineering philosophies at work here and do not endorse one over the other. Only pointing out the differences. I have used SW Motech bars and rack in the past with complete satisfaction. They would be on my current GS if finish matched my Touratech pannier racks.
· Not that senior.
it's not the head thats wet
Why do some people call the new liquid cooled bike a "wet head". the heads are still air/oil cooled, not liquid cooled?
Have a look at this great little engine video.
BMW R 1200 GS. Air--water-cooled boxer engine with vertical flow - Video Dailymotion
· '09 R1200GS + '81 R80 G/S
I have SW Motech bars on my 2008 GS.
I had one spill that was hard enough to rip the LH passenger peg off the rear frame, but the engine bars only got paint chip marks.
Nothing wrong with them at all, in my book. :)
· Not that senior.
Save my money
Just had a test drive comparison on three R1200gs bikes.
I ride a 2004, and had a 2005 GS.
I rode a 2010 model. The only thing i found better was the ability to change suspension settings on the fly. A bit more horsepower was usefull.
A 2013 air cooled runout model....same answer.
A 2013 liquid cooled. Great front end, bags of power, and lots of electronics.
Conclusion. I own the 04 model. ( value in Au$ 13k)
2010 s/h 30 thousand kilometers, all luggage.$22k
2013 run out 3 thousand kilometers, no extras. $24k
New liquid cooled. a few add ons, but pretty much stock $27k
I think my 04 with 60 thousand kilometers will do me for quiet a few years yet.
· Registered
Good video! It’s nice to see the camshafts geared together, less lash on the drive chain. On the last twin cam, inlet & exhaust cams were on the same shaft so no gearing was necessary. As for cooling; all engines are air cooled in a way (even "water cooled" ones) since the air cools the water.
· Registered
SW-MOTECH crash bars
I went with SW-MOTECH bars, saved a bundle. Installation was a breeze and they look good. Fortunately I haven't tried them out yet in an actual crash.
Pic's are from when I installed my alt-rider oil cooler guard.
Regards,
Brett
· Registered
Hii everyone
I am living in Turkey and i am looking for a shop which i can get sw motech products, please help me:)
Hello 1200maniatr.
I looked up the Turkish distributor on the SW-MOTECH site and this is where they direct people:
MotoPlus | Anasayfa
TÜMOPARSAN MOTOR SANAYI VE TIC. LTD.
SULTANCIFTLIGI 2.CEBECI YOLU 2568/2 SOKAK
NO.1 GAZIOSMANPASA
34265 ISTANBUL
E-mail: [email protected]
Phone: +90 212 668 9700
Fax: +90 212 668 9414
· Registered
The BMW bars will still allow the valve covers to contact the ground. You still need the covers which are not necessary with aftermarket bars.
Why?
Serious question. The after market covers take away flex room for the bars. That makes it more likely that the force of any crash will be transmitted to the valve cover/head instead of being dissipated as the bars flex. I don't think that's what you want.
Also, the after market protectors are often about as expensive as the valve covers themselves. If you are going to be concerned about scratches then aren't you also going to be concerned about scratches on the protectors? Replacing either will cost about the same.
If your concern is about a puncture a tube of JB Stik in your gear should cover your worries. I remember a video (Jimmy Lewis?) where a hole in a valve cover was punched by the valve cover protector. Had the rider not had the protectors mounted his valve covers would have suffered no more than a few scratches.
1 - 20 of 27 Posts
