Dear all.
I am the owner of a 1200 GS 2007 that is working like a charm and traveled few places faraway.
I originally connected here in 2009 when I bought this bike but have left for a while.
Now, I have an interesting, but not pleasant behaviour from the bike.
Let me explain the setup and the behaviour.
The bike is equiped with a Navigator VI GPS plugged on the dedicated plug.
Without that device, I would never have noticed below issue.
I also have a set of Led lights with a relay pluged after contact.
I can go on trip for days and have no issue at all.
However, when I plug a device on the accessory plug, below the seat on the left hand side, it happened that both the accessory plug remains active until the battery is drain out.
This do not happened all the time.
I have tried various change but nothing helped.
Removing every accessory, cables, etc etc. Still, the issue happened from time to time.
I found out that, if I remove the - from the battery, the system turns off immediately and return to the normal state.
I've been told this might be caused by a wire that is there to maintain the motorbike in "standby" but I have no idea how to investigate this further.
When checking with GS 911, I have not found any relevant error in the log or actual error.
Thank a lot for your help.
Valken
Valken
