I'm getting my bike ready for next season.
GS R1200 k255 2009year 110 000 km (vehicle mileage in kilometers)
I have already replaced the alternator belt which was in very bad condition.
I did the valve adjustment. Replacing the oil filter. Replacing the air filter.
I replaced the spark plugs with iridium ones.
I did the differential lubrication and oil change.
Cleaning and lubrication of bearings.
Finally got to the clutch.
looks dry at first.
The thickness of the clutch lining is 5.7 cm. so it looks ok.
But I'm not sure about the good condition of the spline in the clutch.
Upon closer inspection, I could see a sweaty sealant.
Does anyone have experience diagnosing what needs to be replaced?
Does this mean replacing the seal?
Clutch friction plate thickness
Is the clutch disc spline worn?
I have a video of the clicking sound. Clutch disc placed on gearbox spline. I will try to put it.
Similar knocking sound with the engine running. depressing the clutch temporarily stopped the knocking.
Is this discoloration normal?
Sorry for the language but sometimes I still make mistakes.
I will accept any comments.
looks dry at first.
