I just installed some $20 Chinese TPMS sensors in my tires on my 2008 R1200GSA after adding the RDC module, and I was dismayed to find they read about 5 psi low. But after more thought, I realized, this actually makes sense.
I live at an elevation of 7,600 feet (2316 m). At this elevation, the atmospheric pressure is actually 3.7 psi lower than at sea level. A tire pressure gauge actually measures psig (psi "gauge"), which is relative to the atmosphere. The way I see it, a TPMS sensor is inside the tire, so it has to be made to measure absolute pressure in psi, not relative pressure in psig. There's no way a pressure sensor that is wholly contained inside the tire can physically make a relative measurement like an external gauge can.
See page 9: https://static.nhtsa.gov/odi/tsbs/2015/MC-10192638-9999.pdf
In addition, the current temperature in my garage is about 80 F (300 Kelvin), although cold inflation pressure is specified at 69 F (293.7 Kelvin), which is a difference of 2.1%. This equates to a pressure increase of 0.67 psi for a 32 psi (nominal) tire. However, TPMS is supposed to be temperature compensated, so it would subtract the increase. Adding these two numbers together gives 0.67 + 3.7 = 4.4 psi. So according to physics, you would actually expect the gauge to read 4.4 psi higher than the TPMS sensor in the wheel, which is pretty damn close to the ~5 psi I measured.
Alright, so with that out of the way, this raises a couple of questions. First, if you live at high altitude, is it OK to have your tires inflated 3.7 psi higher (e.g. 35.7 psig instead of 32 psig). Second, at what pressure loss will the BMW RDC system throw a warning? If it throws a warning with >3 psi loss, then RDC will not work properly at such high altitudes (assuming a tire should be inflated to psig, not psi).
