1 - 3 of 3 Posts
I just removed the tank of my '02 R1150 GSA since it had some fuel hose issues. I replaced a couple of hoses and quick connectors and now I'm having a hard time getting the tank reinstalled. The hoses and quick connector running across the middle section of the tank connecting the left and right side seem to be in the way and I'm not really sure where they are supposed to go without completely bending or stretching them...any tips/ideas?
Thank you!!
Auto part Vehicle Car
I got my throttle cable routed wrong on my 07 GSA when putting the tank on...it was hard to get bolts in to secure tank and engine revved when turning left (interesting feature to have!)
Not sure there is a trick other than watching close as you install. You could use some electrical tape to keep wiring/hoses/cables where they need to be.
That looks wrong. The line connecting the two halves of the tank should run along the bottom seams of both sides towards the seat and then make the turn just behind tank.
1 - 3 of 3 Posts
