When a buddy swapped his front signals out for a shorter set, I realized how annoyingly long my fronts were and decided they looked bad.
But rather than give my friends in Bavaria $90 and spend 3 hours ripping the bike apart as the YouTube mechanics suggest, I turned to Amazon and grabbed a set of generic European style for $20 and went to work.
Started out by removing the lenses, then popped the reflectors in all of 45 seconds. Noted the wire order, and slipped the tabs loose.
After running a drill bit through the new ones (wire channel was too thin), slipped the wires right thru. Needed to crimp the connection ever slightly since the tabs on the new were a bit thinner (yeah, the Chinese models are lower quality than the German), but then they bolted right up.
Left vs right (before and after) and with the new.
