Thanks for the pictures. I looked at ted Porters but he doesn’t have driveshafts for the WC models. I like the idea of having a grease fitting also.
I have been in contact with Ted Porter and he is currently working with a supplier to get a WC drive shaft. A few weeks ago he thought he was about two months from having them available (no parts # or price yet) _ I sense he's frustrated in the delay, when I first contacted him back in October or so I think he expected them sooner.
I have about 75K on my'14 and as I did maintenance this spring prepping for the Butt Lite X (canceled) I found my rear u-joint was very rusty. Condensation, heavy rains, etc. I have a OEM drive shaft coming form Germany that was (about) $850 shipped to my door in Minnesota (should be here soon)
33738531102 BMW Drive Shaft new - KFM-Motorräder (kfm-motorraeder.de)
I am replacing the shaft pro-actively - I'm retired and do long rides in remote areas and having personally known two local bikes that had (rusted) rear u-joints bust in the 90K range - I decide to spend the money now rather than have a roadside "bust more stuff" type failure. (one guy had a lot of housing damage) I do my own work and plan to look for a way to add a drain to the low point once I dig into it. The seals are pretty robust, but are not 100% along with condensation which may effect some riding styles less than others.
btw I was also able to order OEM TPS sensors for $90 each.
