I have just purchased my first gs it is an 07 and I am interested in checking and adjusting valves/rockers. Where is comprehensive instructions for a first timer like me? Right down to what tools I need.
I piece of string like an old shoe string worked behind the wire and up next to the coil head then gently pull out.The MAX tutorials are first rate. Check out the oil change tutorial as well, just for the professionalism of both work and video.
You don’t necessarily need the spark plug tool as a DIY owner-mechanic. A large flat head screwdriver works perfectly fine if you are gentle, at least on my ‘09 it’s never been a problem.
And you can use the same shoestring to open your brake fluid reservoir! BMW maintenance on a shoestring 😁I piece of string like an old shoe string worked behind the wire and up next to the coil head then gently pull out.
Yup and a piece of string trimmer line to hold/maneuver the lower u-joint when raising the rear drive up to mate the splines.And you can use the same shoestring to open your brake fluid reservoir! BMW maintenance on a shoestring 😁
