1 - 3 of 3 Posts
I got all the wiring done for the brakes and turn signals using the ezCAN to hook up into the R1250 GS CAN bus. The issue I am facing is putting back the turn signal cover over the housing. It seems that the keylock provided with the kit (to hold firm the LED circuit board) prevents the cover from aligning with the housing. As can be seen from one of the pics, no issue to fit the cover over the housing without their keylock.
Anyone had that experience?
B.T.W - it's a great product that installs as if it was an OEM part, and the guys in Adventure Design (no personal affiliation or interest) are very helpful with any electric hook up questions. Weiser New Ultra Bright LED 2-in-1 Brake Light/Turn Signal Upgrades (pair)
I got front and back sets of these Weiser lights a couple years back and had the same issue. Called Weiser and they said they reformed that little key lock and they sent me four more and it fixed the problem. Another thing to check is that that little key clicks in place. Hope this helps.
1 - 3 of 3 Posts
