1 - 20 of 30 Posts
Hey everyone!
I've got a R1200gs Adventure (2009), and I own it for about a year.
I have dropped it (while parking or moving backwards) about 4 times and I haven't noticed any damages except for some scratches on the engine metal protectors and handguards.
Can it handle this kind of drops without damages or should I worry about bent handlebar /frame?
GS's are built to handle theses, most of the major components are located in safe places... Expect some cosmetic damages.
Recommend something to cover the heads however. Dropping the bike = no big deal on a flat surface. Dropping the bike and hitting a rock or something that the engine guards miss could equal a big 'ol hole and lots of leaking oil. Worth carrying a coin and some JB weld or steelstick if you don't pony up for some Ricochet engine protectors or something like that (those were my choice). Plenty of youtube videos documenting this - one that stands out - this guy took a brand new one for a test ride, parked it, it rolled off the kickstand, tipped and he ended up paying for a new head cover - cost him several hundred dollars - this was on pavement!
If you're not into deadlifting several hundred pounds, might invest in a dustrider motorcycle hoist. I'm a big dude and can lift my bike pretty easily with good traction. Put 'er down in some clay mud one day and struggled for a solid 2 plus hour to get enough traction under me (and dig pits for the wheels to fall into). I was out in the boonies, would have had to walk to get signal to try to call someone. Got it out and rode home and bought a hoist - keep it in my bags w/me now... just in case that happens again.
Reactions: bobmanz
Discussion Starter · #9 ·
So the cylinder guards it already has might be not be enough?
I would never drive in mud on purpose exactly due to lack of friction, but yeah, you're right
Altrider and others make braces that keep the OEM guards from hinging back onto the covers, and most aftermarket ones are designed so they really protect them in a drop.
No bike should suffer frame damage from a parking lot tipover/dirt(pavement) nap.
Learn how to pick up your bike without injuring yourself. Plenty of YouTube videos. You don't need a hoist if you stay on pavement. If you decide to toss it down a hill or screw up a water crossing, that's a different story.
Reactions: Konstantinos
'05 R 1200 Gs
It is the embarrassment factor that hurts the most. I carry an inflatable exercise ball to assist the lift up in remote locales. Also carry a Cycle Press pump. Only have used it in a test. Works great.
The exercise ball is a brilliant idea! I may have to give that a try - I wonder how it would have worked in my situation - do you just carry a tire inflator pump and a ball inflator needle? (can't think of the name).
Reactions: Southpaw
Yeah my driveway is gravel, and has a downward slope. I as I was hopping of with the engine running it just rolled off the kickstand. So I killed the engine and tried to lift it up, to no avail so she just laid there until I could get some help from my neighbor. Once I got her upright on the center stand I let her sit for about 30minutes or so to let the oil get back where it belongs and fired her up no problems. So from then on I kill the engine and put it gear while l open the garage. Just a couple of gravel marks on the engine guard, kinda gives her a little character.
I remember having my first drop on a stop on the way home with a brand new 1200 RT . I had parked facing downhill (first mistake) had shifted to neutral ( second mistake) and as I hopped off , the unweighting of the bike caused it to roll forward ,folded the sidestand, and scratched the head covers and a pannier. Expensive mistake !!
All my BMWs since have had engine guards installed.
2. Nothing good ever happens in neutral
D O N ' T
E V E R
P U T the B I K E
I N N E U T R A L!
Now that we've covered that ...
I'm on my 4th GS. If I had to guess I'd say I've dropped them a couple hundred times. In some of the worst imaginable positions and places. Through 4 bikes and all of that chaos I might have endured 3 or 4 little scratches in paint. Of course the crash bars get banged up but that's what I bought them for. These bikes are fairly indestructible. You might scratch up the bars and handlebar ends. You may even scratch the back of the mirrors and hand guards in a moving tip over or two. But the bike is fine. Pick it up and ride it. On the extremely rare instance you've punched a hole in the cylinder head cover just patch it with a stick of JB Quickweld and ride on. I've picked up our students boxer motor bikes hundreds of times in the deserts and mountains. Have only seen one cracked cylinder head cover. I did see one get totaled, but it was wheelied off of a cliff. And it looked a helluva lot better than you would have thought.
From my experience coaching and guiding, NONE of the other big bikes are as durable and resilient as the big boxer.
1 - 20 of 30 Posts
