Hi Folks,
I've been suffering some odd idle issues of late. When it's cold, it's fine, starts right up. This issue seems to come and go, and I've not figured out what the issue is.
The first time it stalled on me, I got off a highway and was on some secondary roads, pulled in the clutch and poof, went out. It didn't buck or stumble or struggle, just shut right off. It did this for the rest of the ride home, unless I gave it a bit of throttle, it would stall out.
Next day, started right up, and gave me no issues at all...
During the weekend, I did a valve adjustment, new plugs, airfilter. It was due. Bike still ran fine, for may be a day or two, then started stalling again.
I looked into syncing the throttle bodies and found that they're not done like my older 1100 series. I understand them to be 'preset' from factory and now uses some stepper motors, which, only can be monkeyed with by the throttle cables, to some extent, but that's more of just making sure it has some mm of free play or something... I did tinker with the throttle cables a touch, with a carb sync tool plugged in -- that seemed to give me a much more steady idle once I was done.
It's been a couple weeks now, and it's now started doing it again! This morning though, I have more details. No issue getting off the first highway, no issue on the backroad connectors to my next highway.... and this next highway I only go up one exit. During this travel, I was feeling a touch zesty and ... gave her some pepper. I brought it up to about 6 or 7k rpm in 5th gear. I touched triple digits, had my grin, and decelerated back down as I got off the highway doing about 60mph. I rolled through the first light, took my turn and shifted slowly - and poof she was out again. it continued to do this for the next 4 mins or so -- stalling out if I didn't hold some throttle. I got to the guard gate at work where I have to show ID to get in and it stalled out 3x on me there. Got her fired up and pulled forward in first, pulled the clutch and poof out she goes again instantly.
So, some other things of note:
I've seen it idle at 1800ish rpm.
I've seen it stall out or idle at 800ish rpm.
When it stalls it never does a coughing death. It's instant. Just poof, out.
So, what should I try? I don't have a GS911, and I generally don't use a dealer... but I may be doing both!
Dave
Dave
