Hi, just looking for little advice on 2006 GS1200 expected tank range. Had it about 8 months and love it but only manages around 120 on full tank. This seems quite low, would remapping assist in obtaining greater range? Many thanks in advance.
Hi did you ever find the solution/problem? I have the same issue.Hi, just looking for little advice on 2006 GS1200 expected tank range. Had it about 8 months and love it but only manages around 120 on full tank. This seems quite low, would remapping assist in obtaining greater range? Many thanks in advance.
When did your problem start? Was it after a change to the bike was made? Did fuel economy slowly degrade or was it all of a sudden?Hi did you ever find the solution/problem? I have the same issue.
Thanks, Mick
My Hexheads average for 40 to 44 MPG (US Gallon) depending on how I'm riding.
- Check the caps on the vacuum ports on the throttle bodies are intact.
- If the evap. canister is still in place make sure the hoses to and from it are in good condition.
- Check the coil sticks for proper operation
- Do a fuel pump pressure test
- Check/test the O2 sensors
- Remove any aftermarket fuel devises and/or O2 manipulators and see if fuel economy increases.
