I've owned many motorcycles over the years but I don't recall any without an adjustment to adjust the height of the rear brake pedal. Are there any options out there to raise the pedal height?
Hi, perfect, thanks a lot, will check against that. If anyone else can measure as well, that would be great. Good to have at least two values to see if they are equal.I've just measured it on my 2021 GS.
The shorter distance is 19,5mm and the longer one is 40mm
The number will Varley slightly per bike. These adjustments should not be used to raise/lower the pedal height. If you adjust it one way you'll have no rear brake as the plunger will not be able to travel far enough to actuate. If you adjust it the other way you can make it so even the slightest pressure on the brake pedal will give 100% braking force.
You can adjust the plunger on the bike to actuate properly, it's not a measurement thing. Adjust apply the brake and feel when it engages. If too fast/soon engagent move the plunger away from he MC. and recheck. If it does not engage fast enough move the plunger towards the MC and recheck.
A little adjustment gosa long way. We are not talking multiple turns sometimes its a fraction of a turn to get it adjusted properly.
