I have a 2012 gsa and want to replace the small running light in the headlight assembly with an led. This causes a light fault. Any idea where i can get a resistor to equal the load of the bulb.
I have rethought this, and have decided against the fork mount. The vibration would be substantial mounted below the shock point.I install accessories based on need, and I am going to install some running lights on my forks. That way when I turn the light follows. That's one thing missing from the current setup.
I have put two led strips below the fork mount - attached to the brake calipers. These have a slight background flicker so they are very conspicuous. I can post a photo and give purchase details if anyone is interested.I have rethought this, and have decided against the fork mount. The vibration would be substantial mounted below the shock point.
