I'm looking at purchasing a 2015 R1200GS and would like input on what to look out for.
There are a couple of things I'm questioning:
The GPS (Garmin V or VI?) may have a bad battery as I'm told it wouldn't start up but they were able to get it to start by putting external voltage to it. I'm guessing that means they plugged it into a USB charger. Are there any good aftermarket batteries?...BMW wants $128.
I gather there can be "ghosting" problems with the screen. I did run across a company in Germany that can fix those for around $200.
The GPS doesn't require a data plan to update it or keep it running does it?
I've also read that if you wipe the previous owner's saved trip info you run the risk of permanantly locking yourself out of the GPS unless you have the access code that the previous owner set.
It has an Akrapovič exhaust on it. Not sure if it's just the muffler or the entire header pipe too. For the small HP gain I don't know why it would have been worth adding it on. The exhaust noise seems loud...are they quite a bit louder than stock? It may be that I'm just used to how quiet my old '82 R100Rs was.
Should I be concerned that the seller doesn't have a way to run a computer code check on the bike? If this were a used bike at a BMW dealer it could be easily checked for fault codes. Almost worth buying my own reader to check it out.
Any other things I should look out for? It's pretty low miles so I don't think clutch & final drive splines are a concern yet.
Thanks for your replies.
