Hello fellow GS owners, I'm unable to remove the cap from the reservior because the two spring finger tabs do not compress to release the serrations inside the cap (I've tried using string method and the removal tool). Maybe they have deformed or cracked, I don't know exactly why.
My plan is to take a dremel tool with a cut-off wheel and make gradual cuts as shown below. Then I would pry the cap apart, do my brake bleed and replace the damaged cap components. The objective would be to do this without damaging the reservoir itself and align the cut with the interrrupted sections of thread.
Any other ideas or input would be greatly appreciated. Thanks.
