Cut my windscreen down
5K views 8 replies 7 participants last post by  Krons
#1 ·
My old windscreen was crazed so I bought a new one on Ebay (only around $60.) However, it was taller than I expected so, after some soul-searching, I decided to cut it down. I did it in two 1.5" increments (first time wasn't enough, so I did it again.) Process: 1) Mark screen with marker. I used tape to provide an edge for market to ride on), 2) I used a Dremel tool with a metal cutting brade and mostly just burned thrhough the plastic, 3) Use an air-operated die grinder with a flat wheel and #60 grit paper to remove the melted plastic and smooth the edges, then a finer grit paper (around 200) to smooth it a little more. Bottomline, it was easy to do if you have decent tools. Pleased with the results. I posted this in case anyone else's windscreen is too tall.
Photo 1: Marking the screen with tape for a guide
29797
Photo 2 (below) Going after it with the Dremel. Mostly melts the plastic, rather than cuts.
29798
Photo 3 (below): Looks really ugly until sanded off.
29799
Photo 4 (below): Shows removed strip
29800
Photo 5 (below): Shows finished screen
29801
#2 ·
Nice! I've been been meaning to try this, haven't gotten the guts to do it yet. I've been wanting a short "summer" screen and will give it a go.
Already have a replacement for my current one that'll be my tall screen.
#7 ·
I have a shorty windscreen that barely covers the instruments that I like to have on the bike if I'm going to be off in the woods.
Normally I have the tall Puig screen on it for road trips.
Very nice. The shorty is my next purchase. I have the Puig touring along with the stock screen which is nice, but for the hot months of forest roads it would be nice to have the wind hit the vents on my helmet.
#8 ·
I still didn't give up the idea of fabricating Givi Airflow out of Givi parts. I have Givi Touring screen, that should be cut down to almost half, I have clamps for Givi Airflow and just need to purchase top portion screen that is universal across all Givi Airflow sreens and is sold separately.
