1 - 2 of 12 Posts
Yes, BMW changed the quantity to 180 ml on an oil change. BMW did not say why they changed the level, but most folks believe it had to do with pressure and leaky seals.
In further changes, apparently late '10 and '11 bikes even have an FD vent. I find that somewhat humorous as BMW went from a non-vented drive to a vented drive in the early 60s, too!
In '08 the recommended amount was 250 for the initial fill, 220 for an oil change. You aren't the first person to find more than the recommended amount.
The current specification is for 200 for the initial fill and 180 for an oil change. The new spec apparently applies to the older bikes, too.
1 - 2 of 12 Posts
