Why do motorcycle manufacturers put such wimpy horns on bikes.
What are people replacing the stock piece of junk with?
Have a Stebel on my K1600 as well. Would like to see your install on the GSW when you get it done.I know they do it to save money. I have a Stebel on my K1600 and will put a 2 piece Screaming Banshee on the GSW if I can find room for the compressor.
I will post pictures when I get it done. Today I get a PDM60 so I can bypass the CANBUS. After that everything else will start to fall in line. Monday I get the extra brackets so I can mount the horn portion, I am still looking for a good spot for the compressor.Have a Stebel on my K1600 as well. Would like to see your install on the GSW when you get it done.
Brett can you provide a link to Hornigs video and also do you have a picture of your horn installed.Just installed the Hornig Stebel Horn kit on my wethead. They supply the "custom" wiring setup that plugs into the factory horn plug. Pretty easy to install and if you go out to the Hornig website, they have a video of the install. Loud MF that is for sure
Brett
Here is the link for the video Nautilus Hupe horn BMW R1200GS 2013 by HORNIG - YouTube I dont have any pics of it right now, but I just did what they did in the video. I will try to take some pics. I got the horn kit from Sierra BMW.Brett can you provide a link to Hornigs video and also do you have a picture of your horn installed.
Spence
The after market horns are being installed between the forks. The Horing kit seem to have the best idea so far. I may add a Screaming Banshee solid state relay and controller in place of the relay on both bikes.I'd be interested in seeing any pics of how you guys end up installing your horns.
I am going to try to add a second horn similar in design (but louder) to the OEM horn circuit and see if it will run without the canbus shutting it down, and if it is loud enough to suit me. Will let you guys know how that goes.
This is what I think is happening so today I will remove the Fiamm horn and the Screaming Banshee relay and just use the kit properly. It was worth a try.FWIW, the canbus shuts down the horn circuit in about a second of beeping when two horns are wired in there.![]()
Spence:Today I get a PDM60 so I can bypass the CANBUS.
Spence:Peter
I triggered the PDM60 off of the tail light. Since I run a pair of P3 tail lights under the license plate that was an easy place. It is kind of a pain to get to the first time but it is out of the way as is the P3 controller.
Spence
Spence:As long as the only thing that your are doing with the tail light wire is tripping the solid state relay in the PDM60 then you should have no problems. If you pull any power that is a different story. Even 1 Skene controller will pop a Code, I know I tried.
