1 - 1 of 13 Posts
The EzCan will come with 4 color coded wiring leads with bare wire ends on one end and a water tight connector on the other. The bare wire ends will attach to the +/- of your lights. Look again at the diagrams / pictures in this link: Home - www.hexezcan.com You'll see the leads here.
It really is plug and play. No wires to cut, or splice at all. Simply connect the your light's +/- leads to the appropriate bare wire color coded ones on the supplied EzCan wiring leads, then plug the associated water tight connector into the same color coded water tight connector from the EzCan.
Once you get the EzCan I think you'll get a better picture of what needs to be done. If you need help once you have everything ready to install, PM me.
1 - 1 of 13 Posts
