1 - 1 of 33 Posts
Get one that is "too tall" then you can ride with it awhile, and then, if you want, cut it down to suit your tastes. I used a Dremel tool to cut mine, then sanded with a air-powered die-grinder. After the first pass, and a couples days of trial riding, I cut another 2" inches off. Came out perfect. You can get cheap windscreens on Ebay for around $60 (so if you make a mistake cutting on it, you won't be out too much money.) Photo below shows me sanding on it. Easy if you have the tools.
Finished product
1 - 1 of 33 Posts
