Hi;
I just changed the oil/filter on my 2022 1250GS. The manual states 4L oil capacity. I put in about 3.75 L and it showed as being over filled. I removed the oil filter and drained the oil from it and put it back on, now the oil lever is at the top end of the range. I followed the instructions and had it on the center stand on a level surface. I let it drain for about an hour. I did notice it was still dripping when I put the drain plug back on. Is there an issue where a lot of oil remains in the engine, and it requires some extra effort to drain additional the remainder?
Thanks.
Thanks.
