I know, look at this idiot, joins the forum and immediately starts an oil thread !
I just bought a 2006 R1200GS with 61K, and want to start changing all the fluids, for the bike has been sitting a couple years.
I just read the long oil thread at the top of this forum, as well as other stuff I found through searches.
The info above seems to be exclusively about the water cooled bike with a wet clutch
If I am reading the manual I downloaded correctly, my bike has a 'Single-Plate Dry Clutch'
The manual also seems to recommend 20w/50, but then gives alternate viscosity choices below.
So really I have only 2 basic questions.
Because I have a dry clutch, I can use pretty much any oil, without worrying about JASO-MA2 certifications.......correct?
2nd, In the long oil thread above, many people seem to be using 5w40, or 15w40. Should I really be using 20w50 in this bike?
If I should run 20w50, that will limit the freedom and choices to use non-motorcycle oils.....if that makes sense.
Thank you in advance ! I am no newbie to motorcycles, or motorcycle forums. I know oil threads are taboo, but these are sincere question.
I sincerely appreciate any help and/or advice, but I really don't care if you only use Royal Purple. This isn't at all about brand.
I hope you all understand.
