I've had seat comfort issues with my 2013 GS. Specifically I have always had problems with a sore tailbone whenever I spent enough time on the saddle.
The seat is set "high" in the front and "low" in the back but still leans forward causing the inevitable slide towards the tank. For the life of me I can't
figure why on a bike that is pretty much sit up straight from an ergonomic perspective, they have the seat sloping forward. Anyway, I had a eureka
moment last week and figured a way to raise the front of the seat even further. The front seat carrier is a "plastic" frame that is bolted to the bike frame.
Why not use longer bolts and washers to raise said frame up to lift the front of the seat. After several rides, greatly reduced tailbone issues. Almost gone
entirely! The washers on the front aren't as visible as those on the rear, but they are between the stock aluminum spacer and the new bolt. Total lift is
a skosh more than 1/4 inch.
