1 - 5 of 12 Posts
DucRider
· Registered
2017 R1200GS
Discussion starter · #1 ·
All the standard apologies re ignorance apply here!
So I’ve installed an accessory and have good power. The power unit is under my seat and has an accessory wire that the installation manual says should be connected to switched power so that the unit is powered on with the ignition.
I’ve searched the forum and have found what seems like a dizzying array of options, but none are clear as to exactly what to do.
I guess I’m asking for an ELI5 guide for the easiest method. Though maybe a 5 yr-old shouldn’t be playing with power wires?!
Thanks!
1 - 5 of 12 Posts
