Usually happy owner of a 2014 GSA here. Doing my 36k maintenance this weekend, which included routine flushing of the brake lines and replacing the rear pads. After doing so, brakes felt fine - until several (intentionally) hard stops, at which point the rear break seized up. I couldn't move the brake lever at all, suggesting the system is fully pressurized. After half an hour, brake returned by itself to normal function. Went for a second test ride with only normal braking, no problem. Third ride, with hard braking, and it seized up again. Also found that with bike stationary and running, I could make it seize up again with repeated stomping hard on the lever. Bleeding the system will then release the pressure and return to normal braking.
The calipers were fine when I checked them, brake lever mechanism itself seems fine. No idiot lights came on. ABS seems to be working when tested in gravel. Tested in both Road and Enduro modes, and the rear brake worked fine both alone (Enduro) and when linked to the front brake (Road). Doesn't feel like there's air in the system, and I was pretty careful.
Tried to find old threads diagnosing the problem, and I saw a few mentions of the issue but no solutions.
A few more details: I just flushed out the brake line the old-fashioned way with opening and closing the bleeder valve in time with working the pedal, and I didn't try to do anything with the ABS unit. I didn't hook up a GS911 as I don't have one (yet). Brakes worked perfectly fine before this weekend.
One more detail: This happened once before! About a year and 3500 miles ago, I dropped the bike. When I picked it up, same seizure happened. It loosened up by itself within 20 minutes and didn't happen again until now.
Any thoughts? Ideas greatly appreciated. My own theory is that somehow there is an air bubble that is messing with the ABS, that is then pressuring the brake system, but I would think that would turn on an ABS idiot light or something. Would love to hear your ideas before my next step, which would be to get the GS911 and run it to flush out the GPS fully - after that it's spend money on professional mechanics.
Thanks!
Thanks!
