Good day. My brake lever is very low and I need to bring it up. does anyone know how to do so, or if you have a link to a YouTube video? Thank you
Thank you so much for the info ride safe.Do not touch the brake lever height!!! It's not adjustable per factory specifications! If you do, the rear brake will lock up! diffrent brake lever is the only option.
Sorry, but I respectfully disagree with this.Do not touch the brake lever height!!! It's not adjustable per factory specifications! If you do, the rear brake will lock up! diffrent brake lever is the only option.
The Altrider solution is fantastically thought out and executed. Worth every cent.You could look for an add on for the brake lever to make it larger and higher or get an adjustable lever.
AltRider DualControl Brake System BMW R1200GS / R1250GS 2013-2023 - RevZilla
Avoiding obstacles is all about minimizing reaction time. If you're navigating a tight maneuver, you're likely standing and on the balls of your feet.…www.revzilla.com
