I have 04 r1200gs that came out of Panama, did not come with OEM heated grips. Im wondering if others have added heat by updating the right hand controls, heated grips and weather a non heated grip bike will have wiring provisions for them? I found one factory capped plug under the tank that I beleve is the “optional accessory socket” per the Haynes wiring diagram. Wondering if this could be used? I realize this is Can Bus so the system will limit the amps this socket will produce ( programmed value). Here are some photos of what I think is the socket. Thanks for any insight on this.
