Brake fluid change
I originally purchased a GS-911 because there is no way to reset the oil/service monitor after an oil change. At $400 the GS-911 isn't cheap but if you figure changing your own oil twice a year, the $40 charge by the dealer to reset the service reminder pays itself off in about five years. This evening I changed the brake fluid. The video was helpful but left me wondering how changing the rear brake fluid would flush the abs module. If you don't have the GS-911, you will only be changing the brake fluid by itself. What I missed in the video was by using the GS-911, you will first bleed the rear brake. Then via the GS-911, you cycle the abs pump which then "robs" the new fluid to flush the abs module. Repeat a total of three times and voila! Then you bleed the front calipers as usual. I'm thinking that my payoff time for the GS-911 just got quite a bit shorter!
Jim
