Anyone have ideas on what type of extra lighting that I can install that works with the CAN BUS system (plug and play)?
Mine were really easy. Maybe 30 minutes?how was the installation? Pretty simple? these look really good, im considering the combo set
Hey there curious if you might be the person to ask, as I might be slightly confused. Im new to BMW GS, but not new to making mods on bikes. I was going to get Cyclops or Wieser front and rear 2 in 1 set up. Then add in the Clearwater front LED lights. Ive watched install vids on all. Do I need to add a Canbus system or fuse block? maybe what is the difference? Ive seen that some say the Raider Canbus by Cyclops is the way to go, again just not sure what is required or best set up. Thank you, sir.I Have Both Skene and Weiser
I have had great experiences with both Skene and Weiser. Here's my $.02:
1) Easiest Plug and Play - Weiser Red/Amber Turn Signals - just changing out the stock bulb for an LED board. My photo shows the comparison.
2) Next level - Wieser 2-in-1 Brake/Turn or Skene - both require an extra 12V power lead to energize the lights. You will either tap straight off the battery or go through a fuseblock (I use a PDM-60). If you don't, it'll cause a CANBUS fail as it reduces voltage sensed by the bike on whatever circuit you do tap off. There is also a "trigger" wire that is required to tap off the same signal wire you want your turn signal or brake light to be activated by. This doesn't effect CANBUS - but it's an extra wire you'll tap off (nowadays with a Posi-Tap).
Option 1 above takes about 10-15 minutes. Option 2 is a few hours.
So - If you go Clearwater, you will get their CANopener which will plug into the bike's Tire Pressure or RDC system to interface with the CANbus. This allows you to program all your lights via the Wonderwheel. If you go Denali or HexEZCAN, you will use a phone app or PC to talk the CANbus controller and program it that way. Any way you add a CANbus controller, it needs 12V power from your battery. You can either tap directly to your battery, or put a Power Distribution Module on, and then power your CANBUS Controller and additional lights/circuits as you add them to the bike. I definitely don't think you can put mixed brand CANBUS controller (i.e. one Clearwater and on Hex, etc) but I have seen some installs on "A Bike Thing" using two Denali CANSmarts - look for him (Steve) on Youtube.Hey there curious if you might be the person to ask, as I might be slightly confused. Im new to BMW GS, but not new to making mods on bikes. I was going to get Cyclops or Wieser front and rear 2 in 1 set up. Then add in the Clearwater front LED lights. Ive watched install vids on all. Do I need to add a Canbus system or fuse block? maybe what is the difference? Ive seen that some say the Raider Canbus by Cyclops is the way to go, again just not sure what is required or best set up. Thank you, sir.
They also give a veterans discount if you ask.how was the installation? Pretty simple? these look really good, im considering the combo set
