Hi GSers,
I'm currently preparing a full packing list for an upcoming 4 months, 20k miles trip. The normal packing stuff is easy to come up with, but what I'm lacking is the spares that I should bring, things that usually fail which I can change myself on the road. I've done some research and googling and I've failed to come up with anything concrete. My mileage is currently at 20k miles and I've been faithfully servicing it every opportunity I have. I will be exposed to sand, dust and temperatures ranging from 0' Celcius to 40' Celcius
These are the list of emergency/maintenance items that I will imagine are the things that I should carry with me. I have basic mechanical skills, but I do not think I am able to change a clutch disc on my own without screwing something up royally. But if I have to, so be it and it's better than not doing anything I reckon. I got a haynes manual and have a full set of tools which i will bring with me. I will also do a major servicing of most of the fluids and a full checkup of my bike before the trip.
Pre-Trip Check/Replacement if required
- Valve Clearance
- Brake fluid check
- Brake pad check
- Coolant level check
- Clutch fluid check
- Tires
Essentials
- Full set of tools
- Haynes manual
Consumables/Maintenance on the Road
- Air filter
- Oil filter
- Fork Seals
- Pre-Filter
Emergency Spares (of things most likely to fail)
- Gear shift lever
- Brake pedal
- Fuel Pump?
- Throttle Body?
Will appreciate if I can have some advice on what are the items most likely needing a change or likely to fail. I understand I am unable to carry everything plus the kitchen sink, but having the most important items with me will help me ensure my journey can continue..
- Valve Clearance
- Brake fluid check
- Brake pad check
- Tires
Essentials
- Full set of tools
- Haynes manual
- Air filter
- Oil filter
- Fork Seals
- Pre-Filter
- Gear shift lever
- Brake pedal
- Fuel Pump?
- Throttle Body?
