Put you mind as ease servo assist ABS brakes were abandon after 2006. The 2007 went back to regular ABS brakes. The 2007's if you do have problems with eh ABS Module Master can rebuild them for $250.
$5000 is not a bad price but as always would be better if it had some farkles like panniers, aftermarket suspension, seat windscreen etc.
If you like the bike I'd say go for it. The mileage is of no concern but there are some things that should be checked even before you buy.
- The rubber boots on the swingarm at the rear drive and transmission should be checked for cracks. Not had to replace but they are about $105 for tha pair and for the 1st time it'll take and afternoon.
- The rubber boot on the ball joint at the front shock. Much less involved to replace but it'll still take time and about $30. If it was run for a long time and the ball joint got dirty and needs replaced, then it a lot more expensive.
- With the bike on the center stand kneel on the left side of the bike and grab the wheel at 3 and 9 o-clock and push and pull. If the wheel has more than 1mm of movement the rear dive will need the big bearing replaced. Depending on how much movement sooner than later. Also rotate the wheel 90 degrees and check again. Repeat until you've made one revolution.
- Verify the heated grips work. Start the bike and turn the heated grips on. Within about 20 or 30 seconds they should start getting hot.
- Pull the seat and see what it looks like underneath. If it clean, dirty or a rat's nest of accessory wring. Unfortunately, many DIY'ers think they are 12v electricians because they got the socket or aux light to power up. The reality is they string whatever wire they could find and use cheap automotive connectors with electrical tape holding it all together. I rip all that stuff out and do it poperly.
Once home it's a good idea to hinge the rear drive down to clean, check and lube the driveshaft and rear drive splines with a good spline lube or high impact grease.
Cheers,
P-14
