Noticed a buildup of oil or grease at the transfer case. Any ideas what’s causing this? Thanks!
Hello, how are you? Check if the wheel has any axial play, as there should be a seal between the disc and the transfer case. Check if the fluid has been replaced and if it has not exceeded the limit, a broken bearing, or anything like that, which could lead to this problem.View attachment 42718
