I have an issue with the 2013 r1200 GS lc K50 engine.
The engine is blocked and can't start, since the crankshaft can not rotate.
I relised that issue is not due to the left cylinder head nor right one.
I removed engine from the bike and put out the crank disks . Engine remains blocked.
I need to remove the gear box now while engine is blocked almost in TDC(Top Death Center)
As crankshaft can not rotate in BDC( Bottom Death Center), what is appropriate to do in order to remove the gear box ?
