This is the google translation from Italian. Sorry for mistakes. Do not have time to fix this now.
Please see if it makes sense. It looked believable to me.:
"A typical FAQ is how effective a SMART IAT is, and how the LAMBDA probe behaves after changing carburetion in this way. The common objection is that the Lambda probe "becomes aware" of the modification, canceling the benefit initially obtained after a while.
Specifically, many have asked me: "... but after a while 'signal Lambda does not report the carburetion to the factory by nullifying the fattening obtained with the SMART IAT?"
The answer is obviously "NO" otherwise it would not have made sense all the disquisition up to here produced. The reasons are essentially two:
1) The operating environments in which these two probes work (iat and lambda) are different. The Lambda operates only in certain regimes and especially in "closed loop", when the engine is at constant regimes and constant gas openings, while the IAT gives its most contribution in the "open loop", in the "open and close". That is to say when we ask for or remove power or we ask for more fuel to the injection system (and the lambda signal is temporarily ignored by the ECU). Put simply, calibrating a gasoline increase through the IAT is a rational operation, doing it through the modification of the NO lambda. With this point I also made it clear why I DO NOT MODIFY THE LAMBDA, nor do I think it makes sense.
2) The modification of the carburetion obtained with the SMART IAT is cmq relegated to a precise "range". We are working on an engine that works in stoichiometric conditions. We are not increasing the "nose" petrol as you would with a fixed resistance or with potentiometers, but we are acting in a precise way so as not to go beyond the optimal level of air / fuel ratio which returns the best performance. And with this point it is also unveiled why someone claims to the sword that modifying the iat is stupid or an urban legend. Those who have tried with resistors, potentiometers or incorrect NTCs, have modified the power "ad minchiam" (as the Romans used to say) and sooner or later the lambda feedback intervened, which smoothed everything that had been done inconsiderately on the IAT signal. Understand now why the additional modules require the disabling / modification of the Lambda (and someone wrongly implements only that)?
With this paragraph I hope to have definitively thwarted doubts and skepticism about the relationship and functions of lambda / iat."
